pulse width modulation
Discussion in 'The Projects Forum' started by 016chris, Nov 20, 2007.
  1. 016chris
    Oct 30, 2007
    5
    i am trying to make a dimmer switch circuits using pulse width modulation to dim a 5 volt lamp. The circuit needs to be powed by AAA bateries and power a 5 volt lamp. Can any one recommend any good sights to look for one or email me a good circuit
  2. iONic
    Nov 16, 2007
    1,422
    68
    Incandescent lamps are very sensitive to changes in the supply voltage. These characteristics are of great practical and economic importance. For a supply voltage V,
    * Light output is approximately proportional to V
    * Power consumption is approximately proportional to V
    * Lifetime is approximately inversely proportional to V 16
    * Color temperature is approximately proportional to V 0.42
    Not that you need all this info. There are a gazillion sites dealing with PWM and lighting.
    You might want to study the data sheet for the LM555 Timer. http://cache.national.com/ds/LM/LM555.pdf in particular the monostable mode.
    Also: check out this article: http://electronicdesign.com/Articles/Print.cfm?ArticleID=11028
  3. GS3
    Sep 21, 2007
    408
    35
    The first one is notoriously false. I went to Wikipedia to check and saw you copied from there but left out the exponents.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    With a five volt lamp, a pot changing base current into a transistor should be all the control necessary.
  5. GS3
    Sep 21, 2007
    408
    35
    Except that the OP explicitly asks about doing it with PWM and also there is a question of using AAA batteries anda 5 V lamp which I am not quite clear about.
    And then there is a question about "good sights" which I am not sure how to interpret. ;)
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I believe that might be "good sites".
  7. 016chris
    Oct 30, 2007
    5
    yes sorry that is what i meant good sites
