pulse width modulation
Discussion in 'The Projects Forum' started by 016chris, Oct 30, 2007.
  1. 016chris
    Oct 30, 2007
    5
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    What were you planning to use the PWM circuit to do?
    hgmjr
  3. GS3
    Sep 21, 2007
    408
    35
    Do you realize that the "flasher" function is exactly the same as the "dimmer" function but with a longer period? All it does is embiggen C2 by putting an additional 10 uF in parallel. You don't want the slower flash possibility? Then all you need to do is keep the S1 flash switch open or simply not install the capacitor in question.
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Omit both S1 and C3.
  5. nareshkumar
    Apr 16, 2009
    what is mean by the advance variable speed motor and speed drive avs1000 or advance vector speed motor and drive
