Pulse to steady signal
Discussion in 'General Electronics Chat' started by newuser1029834535, Jul 22, 2016.
  1. newuser1029834535
    Jul 22, 2016
    I need to make a signal from an IR sensor to last at least half a second. The original signal may last very little so I need to make it longer. What kind of IC/circuit do I need to build?
  2. benta
    Member
    Dec 7, 2015
    101
    24
    Monostable multivibrator. I'm 100% certain someone will suggest a 555.
    Benta.
  3. atferrari
    Jan 6, 2004
    2,664
    784
    Even with transistors or a very small micro...:)
    The key expresion for a search is "pulse stretcher".
  4. AlbertHall
    Jun 4, 2014
    2,262
    448
    If you can't do it with a '555 it's not worth doing ;)
  5. dannyf
    Sep 13, 2015
    2,196
    417
    the answer depends on what you meant by "long".
  6. BillB3857
    Feb 28, 2009
    2,402
    348
    Or PVC pipe!
  7. benta
    Member
    Dec 7, 2015
    101
    24
    That's the best post I've read in a long time. My stomach muscles still hurt from laughing. However, I'm still waiting for the suggestion that a 555 is the ideal gate driver for a 300 A IGBT. But it will come one day...
  8. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,691
    1,297
    Why? There are hundreds of pulse and timer circuits. A few more details will help narrow the choices.
    What is your application?
    What is the output pulse used for?
    What voltage does it need to be?
    How much current must it source or sink?
    etc.
    ak
