Pulse Response Homework Help
Discussion in 'Homework Help' started by testing12, Mar 19, 2011.
  1. testing12
    Jan 30, 2011
    80
    Hello everyone,
    I have yet another question reguarding pulse response:
    I need some help determining i(infinity). I have tried mesh analysis for il and tried using VL = L di/dt but i got an answer as a function of the derrivative of u(t).
    I have 2 problems with the solution:
    1) why can we assume u(t) is 0 at t=0, its an unknown function.
    2) how do they get i(infinity)
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    u(t) is often referred to a s the Heavyside function which is defined as
    u(t)=0 for t<0 and u(t)=1 for t>=0
    For i(∞) simply consider the inductor as a short and solve the circuit as if it were a purely DC circuit.
    The problem you posted doesn't appear to explicitly state the value of Vs. Was this given in the problem somewhere?
  3. testing12
    Jan 30, 2011
    80
    ok i got it, but i have some problems with it:
    How can they assume that as iL(0) =0 and Vs(infinity) = 9 volts.
    when u(t) is there, its like it was completly ignored, then added in the final answer.
  4. testing12
    Jan 30, 2011
    80
    quick reply t n k, i posted at the same time as you :)
    thank you sir!
    NOTE: yes Vs was given in the problem to be 9u(t) volts and i was asked to solve Vo (t).
    Thanks for the information reguarding u(t), i had no idea what that was!! I will think of it as the on/off switch at t=0.
    note for student reading this: http://en.wikipedia.org/wiki/Heaviside_step_function
    Very interesting!
    final note: i should also mention the solution manual is slightly older then the edition of my text and my text has the solution as
    vo(t) = 3e^(-4t) u(t) volts, which is what i got when i solved.
