pulse rate counter
Discussion in 'General Electronics Chat' started by Hassaan Aslam, Apr 21, 2013.
  1. Hassaan Aslam
    Apr 20, 2013
    11
    i have have a frequency counter by using 7493 ic, a flip flop and a 7447 decoder. now i want to modify this circuit to get the frequency rate or the pulse rate. Can any one help me how to use a latch to modify this circuit. the circuit is attaches as attachment.:(:(:confused::confused::confused:
  2. ScottWang
    Aug 23, 2012
    4,930
    777
    A frequency counter need a time base as 10Mhz, 4Mhz, 1Mhz, it's using decimal counter to divide to 1Hz, the time base will affecting the accuracy when we measuring the frequency.
    I can't see the crystal time base and 1Hz.
    If you just using 4 digits then maybe you can using 10Khz for the pulse rate, you also need a AND gate, the 10Khz and pulse should be connecting to the AND gate, and it will start to count when the pulse in the rising edge, and the counter should be stop to count when the pulse in the falling edge.
    The 10Khz can be get from 1Mhz divided by 100, one CD4518 can do the job.
  3. GopherT
    Nov 23, 2012
    6,309
    4,030
    In simple terms, to measure how many pulses you have each second (Hz = cycles per second), your circuit needs a proper 1 second time period to collect pulses.
