Pulse Induction Metal Detector
Discussion in 'General Electronics Chat' started by r_james14, Apr 28, 2010.
  1. r_james14
    Apr 23, 2010
    9
    Hi
    I am trying to make a Pulse Induction Metal Detector however am unsure in the best approach in either using a little electronics and a micro controller or doing it without a micro controller, can anyone recommend an approach or a good information source.
    James
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Can you tell us some more about how this type of metal detector works?
  3. hgmjr
    Jan 28, 2005
    9,030
    214
  4. rjenkins
    Nov 6, 2005
    1,015
    69
    That 's the first time I have heard of that system, it is interesting.
    It does not look like it needs anything exotic component-wise, but you will definitely need a reasonable oscilloscope to monitor the 'transmit' current pulse waveform and decay time. If you can get a really clean, sharp cut-off the rest should be relatively easy.
    I'd start with a basic sample-and-hold amp for the receive side, on an adjustable delay.
    Once you get the basics going, you could always add a PIC or similar with an LCD to give a display & adjustable delay times for discrimination or 'echo' waveform graphic.
