PULSE GENERATOR/ CALIBRATION/ 555 TIMER /
Discussion in 'Homework Help' started by h9898, Jun 18, 2016.
  1. h9898
    Jun 18, 2016
    I have been told to build the following circuit and adjust the POTS so that the pulse generators produce a 2:1 mark to space ratio and a 6KHz output.
    ok so i have managed to adjust the width to achieve that, however i now must adjust VR1 ( adjust graph height) so that that output is 5v. my question is why must the output be equal to 5V ?
    thanks
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    VR1 does not adjust the output voltage. Did you mean VR2?
    John
    h9898 likes this.
  3. h9898
    Jun 18, 2016
    Yes i apologise, VR2 adjusted to about 53% gives a 5v output, ,,, also the iput battery is 9v not 5v.
    thanks
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    That makes sense now, because the 555 is not "rail-to-rail." That is, it can't drive its output completely to its supply levels.
    As for your question of "why 5 V," I assume it must be feeding something downstream that needs just 5 volts, not 7 or 8 volts. A microcontroller would be an example of one such device.
    John
    h9898 likes this.
  5. h9898
    Jun 18, 2016
    thanks for your help
  6. JoeJester
    Apr 26, 2005
    3,393
    1,211
    The output is NOT variable, the output requires 2/3rd of the period to be high and 1/3rd to be low. The period remains constant (1/6 kHz). In your drawing, the frequency changes.
    You might want to revisit your schematic.
    Can you post a picture of the assignment's statement.
  7. jpanhalt
    Jan 18, 2008
    5,699
    909
    @JoeJester Check out Posts #2& #3. There was a misstatement in the original question.
    John
