pulse dc voltage
pafrazier
Joined Jun 4, 2011
57
What would be the best way to pulse dc voltage on and off from a battery across wound copper coil? Would that resonate the coil at it's resonate frequency?
wayneh
Joined Sep 9, 2010
17,498
No one can answer without a lot more information, such as the inductance, impedance and resistance of your coil, and any other circuit components. A pure inductor doesn't have a resonant frequency. Of course real devices have capacitance.
pafrazier
Joined Jun 4, 2011
57
The inductance is 207.306 uh
self capacitance is 5.901 pf
resistance is .197 ohms
dia 4.5 inches
16 gauge mag wire.
impedance .2 ohms, Not sure if this is correct. I used online calculator.
The circuit is basically this coil hooked up to a battery. Adjusting the current with a resistor. Battery is 1.2 volts.
Is it possible to pulse dc voltage across this coil?
wayneh
Joined Sep 9, 2010
17,498
Yes, you just need to compute the frequency and current, and then choose an oscillator design and parts that can meet those specs. Do you care about the waveform (eg. sine vs square)?
You should elaborate on what you you're hoping to do. Radio? Inductive heating? Experts here can and will help a lot more if they know what the goal is.
pafrazier
Joined Jun 4, 2011
57
I am experimenting with resonant circuits. I am not sure yet on frequency or current. Can you expand more on the oscillating design. Do you have any examples of what those circuits look like? Any websites?
wayneh
Joined Sep 9, 2010
17,498
For frequencies below about 1MHz, many an experimenter would use the 555 timer IC. You can find lots of information on it on this website. Crystal oscillators are also handy because they are so simple; power in, accurate clock out. Done. And you can get much higher frequencies than a 555 or an op-amp. But both the 555 and a clock will generate square waves.
pafrazier
Joined Jun 4, 2011
57
Do you have a simple circuit diagram using a crystal oscillator?
1.5 mhz frequency pulse, square wave
1.2 volt battery
.012 amps
wayneh
Joined Sep 9, 2010
17,498
I don't know if there are oscillators available that will work at that low a voltage. They're used to generate logic clock signals, and those are usually higher output. The other specs should be no problem - just go shopping.
You might enjoy this project, wherein I used a 1 MHz crystal oscillator as a radio transmitter.
wayneh
Joined Sep 9, 2010
17,498
Is that 1.2v battery your only power source? If you can use a higher voltage to control it, a MOSFET would make a fine switch. The higher voltage wouldn't have to run anything except the MOSFET, and the 555 timer to set the frequency.
pafrazier
Joined Jun 4, 2011
57
I can use the minimum voltage to run the components. What would I need fo supply? What wouild the circuit look like?
wayneh
Joined Sep 9, 2010
17,498
Drawing something isn't handy right now, but look up 555 timer circuits, in particular a square-wave generator such as described here. (You can use an op-amp or a comparator IC for the same purpose.) That will give you a way to make a variable (potentiometer-controlled) frequency clock.
The output can then be applied to the gate of an n-channel, logic level MOSFET which will act as a switch; conducting when "on" and not conducting when "off". Logic level because you want low voltage; a "normal" MOSFET needs 10V to switch on. It would be best if you can put your MOSFET switch between the battery "-" pole and the inductor, instead of between the inductor and resistor, with its "source" pin connected to ground and the inductor connected to the "drain" pin.
On a positive clock pulse, the MOSFET will conduct from drain to source for as long as the pulse remains positive (gate versus source pins). A low gate voltage (no or low voltage of gate relative to source) will turn off the MOSFET and it will not conduct.
You'll need about 4V minimum to make this all work.
