Anybody out there know of a tried and true pulse circuit for a hydrogen
assist system for a vehicle?
Congratulations! You are almost there! The only convincing you have left to do is to turn it off and see if the mileage drops back down to 28 or stays up at 45. If it drops back down with the hydrolizer turned off, you may well make a believer out of me! If it stays at 45 with the hydrolizer turned off, then you've just tweaked your mechanics and done nothing else.I did a little experimenting with this. I presently have a HH0 unit I designed & installed in a 1990 Chevy Cavalier. Some of the Ideas I got off the web. I tested & experimented with it, the last Six months. The car went form about 28 miles to the gallon to 45. My pulser & EF1E are combined as one unit. Running about 9 AMPS. About the same draw as the headlights. I have it so I can switch it on & off with just a switch while running.
by Aaron Carman
by Don Wilcher
by Duane Benson
