Pulse charging dates back to the 60s, the Dutch called it electrophoor. Originally for extending the life of zinc/carbon cells, it borrows from an electroplating technique of periodically reversing the current flow to get smooth even plating - just raw DC would plate some of the zinc back on the casing, but it was rough and granular. Putting a resistor in parallel with the half wave rectifier put a small reverse flow between each pulse of raw DC current.Hi MikeML thanx for your honest reply.But i have seen in come cases even vibrating(very less frequency as conpared to pulse charging) the battery before discharging leads to increased capacity and im talking of newly formed battery that is not subjected to any electrolyte straticification.Is pulse charging really that great??
The same method applies to nickel chemistry, especially Ni-Cd. Years ago I experimented with this, but found the results with 50Hz unimprssive. In the end I used a capacitor coupling with a selected combination of fast silicon and Shottky-barrier rectifiers on the transformer output of a surplus SMPSU.
The circuit was the basic capacitor input voltage doubling rectifier, the forward pass rectifier was the basic fast silicon so the Trr produced the required reverse spikes. The clamp rectifier was SB to limit the amplitude of the reverse excursions. The arrangement worked brilliantly with Ni-Cd cells, but the results with Ni-Mh were less impressive.
Most of the so called "intelligent" chargers have a pulse charging mode, that applies to both nickel & lead chemistries - so far I've not bothered taking any measurements.
