Pullup resistor on input pin
Discussion in 'Embedded Systems and Microcontrollers' started by Dritech, Apr 17, 2015.
  1. Dritech
    Sep 21, 2011
    756
    5
    I am using external interrupt 0 of the 8051 MCU which is connected to to switch. Do I have to use a pull-up resistor? Also, do I have to set the pin as input?
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    It is best to start a new thread on a new topic.
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    What processor?
  4. MrChips
    Oct 2, 2009
    12,624
    3,451
    Yes, the pin must be configured as input.
    A pullup resistor is required. Some microcontrollers have the pullup resistor as an optional feature. Check the datasheet of your MCU.
  5. Dritech
    Sep 21, 2011
    756
    5
    I am using the 8051 MCU.
  6. MikeML
    Oct 2, 2009
    5,451
    1,066
    Download and read the data sheet. It will spell out the requirements on a pin-by-pin basis.
