A couple of questions on pull up resistors for CMOS. In particular a TS339 comparator. I am confused about the leakage current. I assume since the resistor is tied high that it is going from resistor to the IC. But using this current how do you come up with the resistor value? What parameters do you need to know? And what is the math and why?
Thank you!
Thank you!
