pull up resistor question
Discussion in 'General Electronics Chat' started by bcnice99, Mar 5, 2014.
  1. bcnice99
    Mar 5, 2014
    If a pull up resistor is to make the voltage on an input pin high, how does that work since there is a voltage drop across the resistor? Doesn't that mean the voltage coming into the pin would be near 0v since it dropped when going across the resistor? I'm sure I have something backwards i my head.
    Thanks for the help
    Brian
  2. wayneh
    Sep 9, 2010
    12,391
    3,246
    Depends on the input. For many devices such as op-amps, the impedance is very high, say 10MΩ. A pull-up resistor of say 10K would indeed drop a bit of voltage, but a tiny amount compared to the 10MΩ inside the IC. If your "input" is one pole of a lightbulb, then the same 10K resistor would drop almost the full voltage and very little would be seen across the lightbulb.
  3. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    In what context TTL, CMOS, OPTO?
    Generally pull-up implies a high impedance input, so there would be next to no drain through the pull up, and register a HIGH.
    Max.
  4. praondevou
    Jul 9, 2011
    2,936
    489
    You have to consider the input impedance of the circuit the pull-up resistor is connected to. It is usually much higher than the pullup resistor value.
    Think about it as a resistor divider:
    VCC - pullup resistor - high impedance input - GND
    Almost all voltage will be on the high impedance input, almost no voltage on the pullup.
  5. bcnice99
    Mar 5, 2014
    Ok I was using an Arduino Uno and just trying one of the beginning circuits. I'm not sure what the impedence on the input pin on the Arduino is. I realize the Arduino also already has a pull up resistor built into the controller, I was just confused when I started reading around on pull up resistors and could not get things straight in my head. It sounds like then that the impedence on the Arduino pull up resistor must be greater than the resistor that is being used in the circuit I am trying.
  6. ErnieM
    Apr 24, 2011
    7,439
    1,627
    Well... it depends. As long as you leave it as an input, and keep the voltage on the pin within the range of Vss (or ground) to Vdd (Vcc?) (the supply voltage pin) then it will look like essentially an open circuit.
    If you go above Vdd (Vcc?) the input will look like a diode to Vdd.
    If you go below Vss (ground) the input will look like a diode to Vss.
    And if you make the pin an output it has a very low impedance.
  7. GopherT
    Nov 23, 2012
    6,315
    4,039
    Just to clarify one more way, an input pin should have a default value, you cannot just leave it floating. That is, you can't have a switch that connects/disconnects the input to ground and assume the pin is high if the switch is open (pin not connected to anything). You can not assume the reverse either, that the pin is connected to ground if the switch open and connected th +5 volts when the switch is closed. Therefore, you must connect the pin to ground (pull down resistor) or +5v (pull up resistor). Since no current is flowing (very little current is flowing) into the high impedence input, you can assume the pin voltage is the same as the rail it is pulled to. Them if you connect a copper wire between pin and the opposite rail, you insure (a) you don't have a short between common and power rail and (b) that the new state of the input pin is what ever rail the bater copper wire (or switch) is connecting to.
