Pull down resitor
Discussion in 'General Electronics Chat' started by temuri, Oct 11, 2013.
  1. temuri
    Aug 25, 2013
    12
    Hi!!
    i am having a problem with l293D motor driver. My enables are at a high logic even though they not connected with pwm input. I thought of a pull down resistor but i dont know what value of ohms i should use??
    btw i am driving two gear motors...
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    Use 1K resistor.
  3. ScottWang
    Aug 23, 2012
    4,933
    777
    The following messages on the first page of the L293D datasheet -
    When an enable input is high, the associated drivers are enabled and their outputs are active and in phase with their inputs.
    So if you pull down the EN then the L293D won't work, pull high to Vcc1 and pull down to GND.
