A bit of a bump...The NE5534 is not a pin-for-pin replacement (it's single vs dual opamp), requires a dual supply, and has a 0.5mV or higher input offset.
The CA3140 has basically the same input offset specs as the LM358, requires a dual supply, and can't output more than Vcc-2v, so with a Vcc of 5v, 3v would be the maximum out voltage.
Both opamp designs are pretty old.
Even if you obtain a more modern RRIO opamp, it's going to be tough to get below ~10mV out without using a dual supply.
Are you committed to using a single 5v supply for this project?
Does the board already exist, and is that why you are looking for a pin-compatible replacement?
So after getting V1 working and seeing what you were warning about, I now have V2 working will your suggestions. So far, much better! Thanks!
Last thing I need to do is sort out what you were talking about in terms of filtering. I have a 10nf cap alongside a 10uf cap next to the opamp. Once I hook up the MCU I will be able to see if it is less noisy and accuracy.
thanks again for the help
