Hi Folks,
I've got a shunt (75mV/300A) and built a small op-amp circuit to bring the 75 up to 2.8V. Before you connect the shunt, the input is floating and as such, the op-amp has an output.
How do you determine the value of a pull down resistor? When the op-amp's input is floating, the output is 3.6V (curious as to why that voltage) so "Simples" I said, add a pull down resisitor. I first opted for a 1M thinking anything less would skew the output from the shunt.
I decided to try a 220K, put it in and tested. The output when the pin was not connected to the shunt (yet not floating) was 300mV. When connected it seems to work ok.
if I short the input to ground, the output is zero.
Seeing as 300mV is still not zero, how would I calculate what pull down is needed which will a) hold the output at zero and b) not affect what the shunt is trying to do?
TIA
Cheers,
Crispin
TIA
Cheers,
Crispin
