Pull down resistor on PNP transistor switches
Discussion in 'General Electronics Chat' started by vinnywilliams, Oct 3, 2014.
Thread Status:
Not open for further replies.
  1. vinnywilliams
    Oct 3, 2014
    5
    What are these pull down resistor on the PNP transistor switches used for?
    The pull down resistor goes to a Negative supply -12 volts, if there is a +5 volts on the base or a +12 volts on the base of the transistor, wouldn't the -12 volts and +12 volts cancel eachother or voltage divide?
    I don't get how this can work
  2. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
  3. wayneh
    Sep 9, 2010
    12,382
    3,238
    In each case the pull-down ensures that the transistor is on and conducting unless the signal at the base exceeds the pull-down and turns off the transistor.
  4. vinnywilliams
    Oct 3, 2014
    5
    Without using the pull down resistor what would happen?
    If you have -12 volts on the base and exceed the base with +12 volts, i would think it would cancel or short out
  5. vinnywilliams
    Oct 3, 2014
    5
    I don't understand how this series pass transistor works with this pull down resistor to a negative supply
    The pull down resistor is on the collector, but it's going to the input of a Gate.
    why a series pass transistor going to a input to gate?
  6. crutschow
    Mar 14, 2008
    13,492
    3,372
    It's not entirely clear what all these circuits are doing since you only show part of the schematic but it each case it would appear the transistor is being used as a switch.
    In general you just calculate the transistor state based upon the transistor bias voltages. If the voltages are such that the base-emitter junction is forward biased (base more negative than the emitter) with a collector resistor going to a negative voltage then the transistor will be ON and the collector voltage will be close to the emitter voltage (transistor is saturated). If the base emitter voltage is such that the base-emitter junction is near 0V or reverse biased (base more positive than the emitter) then the transistor is OFF and the collector voltage will be near the negative voltage source of the collector resistor.
  7. shortbus
    Sep 30, 2009
    4,095
    1,680
    Hi BillyMayo, long time no see. Still working on avionics?
    absf likes this.
  8. takao21203
    Apr 28, 2012
    3,578
    463
    its of course too much effort to resize a picture. Dont view 2 mbyte black/white schematics.
    absf likes this.
  9. takao21203
    Apr 28, 2012
    3,578
    463
    What sense does it make without presenting the whole circuit- at least what it is good for.
    It is either "not knowing how to ask" or intentional trolling.
Thread Status:
