PT4115 Led diver
Discussion in 'The Projects Forum' started by LauraB, Feb 1, 2014.
  1. LauraB
    Dec 15, 2011
    43
    Hello
    I built this circuit:
    http://www.laro.com.pl/pdf/pt4115.pdf
    I use:
    Led3W I~700mA
    100uF capasitor low ESR
    Schottky SS16
    Rs 0.13Ω
    coil 100uH
    I dont use these four diodes for the bridge, because I use a DC power supply.
    For dimming I used mC and a function generator. As far as I understand if I just leave this pin, it should be always on. Right?
    I lost a few circuits, because it makes a short between GND and SW. The diode just blinks and thats it.
    What can be wrong? A component I use? Or smt is wrong in my circuit?
  2. TANDBERGEREN
    Member
    Jan 20, 2014
    74
    What is Your input DC voltage?
    And beware of the polarity.
  3. paulktreg
    Distinguished Member
    Jun 2, 2008
    622
    124
    You shouldn't just leave the DIM pin floating. Connect it to +ve rail. Then what happens?
  4. LauraB
    Dec 15, 2011
    43
    My DC input is lab power supply. max 1.5A, 24V. I set it to 12V normally. And about 700mA.
    If I conect Dim to +5V it does the same... In the datasheet it's written: "The DIM pin is pulled up to the internal regulator (5V)
    by a 200KΩ resistor." So I should be able to leave it floating?
    I tried some different things and sometimes Led was lighting, but the regulator wasn't working. It's hard to test it, because every time I need to remove and solder another smd circuit. I already lost about 10-12...
    And a polarity; I connect Led's minus to the coil and plus to the resistor. The schottky diode's "line" to Vin. Is this ok?
  5. paulktreg
    Jun 2, 2008
    622
    124
    You mention you set your power supply to about 700mA. Why?
    If there's nothing wrong with your build this shouldn't matter. You aren't hitting the current limit on your power supply are you? The LED current is approximately 700mA, it could be more?
  6. LauraB
    Dec 15, 2011
    43
    Yes, thats true. I set 700mA for testing. Before I was trying 1A. I dont want to destroy the Led during the tests. Is that a problem? If I set too low current?
  7. paulktreg
    Jun 2, 2008
    622
    124
    If your power supply hits its current limit it may drop the voltage.
  8. LauraB
    Dec 15, 2011
    43
    well, I don't think it hits the limit. I has a display with a voltage and current so I can always see.
  9. takao21203
    Apr 28, 2012
    3,578
    463
    using current regulated power supply with switching circuit- it could not get much worse.
    It can not work correctly, you need to remove the limit.
  10. LauraB
    Dec 15, 2011
    43
    Ok. I will do that. Can I use another lab supply, but this one has no current regulation(Only voltage)?. It has max 5A. But in the other hand, if this won't work... my led will be destroyed. Am I right?
    I used before rectified 15V 800mA and I think there was a problem as well. Anyway, I will try. Could you tell me why I can't use a current regulated power supply with switching circuits?
  11. spinnaker
    Oct 29, 2009
    5,065
    1,174
    What do you mean the LED blinks? At what rate? Are you using the dim pin yet?
    I built the attached pt41115 supply some time back and it seems to work fine. I left the dim pin float.
  12. LauraB
    Dec 15, 2011
    43
    I mean it flashes for a sec and it stops for good. At 12V 0.7mA-0.8mA. I tried to use dim pin but it was the same. Tomorrow I will rebuild the circuit with a different dc supply.
    In the schematic you attached there is a capacitor with plus connected to the GND?
  13. spinnaker
    Oct 29, 2009
    5,065
    1,174
    There is a 10uf to ground if that is what you mean. It is the only cap on the board.
  14. spinnaker
    Oct 29, 2009
    5,065
    1,174
    Where did you get the pt4115? I bought mine from eBay then later got an email from eBay saying the part was a bogus part but everything I seem to see they work fine.
  15. LauraB
    Dec 15, 2011
    43
    I got mine from two different shops.
    But that capacitor is reversed... Plus goes to Gnd and minus to Vin. Is that ok?
  16. spinnaker
    Oct 29, 2009
    5,065
    1,174
    Typo. Thanks for pointing it out. Obviously I installed it right on the board. :) I will correct.
  17. LauraB
    Dec 15, 2011
    43
    No problem Spinnaker.
    I connected 120V max 5A power supply. The circuit is burning, I can see the smoke. The led lights. But i haven't measure the current, cuz anyway it's burning. ehh
  18. spinnaker
    Oct 29, 2009
    5,065
    1,174
    120V ac or dc?
    Seems awfully high either way. I will try and check my datasheet but have to run right now.
  19. LauraB
    Dec 15, 2011
    43
    I'm sorry. I meant 12V DC. Sorry for the misspell. Maybe it's because a schottky diode?
  20. spinnaker
    Oct 29, 2009
    5,065
    1,174
    I assume the chip is SMD? As I recall it is only available in SMD. Did you mix in through hole components like I did? If so are you certain you have everything connected correctly? I know I had to think about how to orient the chip in relation to the components on the other side of the board.
