PT 100 3 interfacing
Discussion in 'Embedded Systems and Microcontrollers' started by anujab9, May 16, 2008.
  1. anujab9
    May 16, 2008
    Hello All,
    I want to interface the PT 100 to meshnetics module(Zigbee wireless platform).
    This module has inbuilt ADC.
    Its 3 wire PT100
    The temperature range is -20 ºC to 400 ºC.
    Right now I am using Wheatstone bridge with INA326 instrumentation amplifier.
    This works well with Range of 0ºC to 400 ºC
    So, What changes should I made to measure negative temperature?
    Regards,
    Anujaa
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Can you state the problem you are having? Is the signal from the INA a problem? We would need a schematic to have some idea of the circuit.
  3. nanovate
    Distinguished Member
    May 7, 2007
    665
  4. anujab9
    May 16, 2008
    Hello
    its just interconnection of brige and instrumentation amplifier
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    You won't be able to read negative temperature directly with a single supply amplifier. You'll either need an old-fashioned dual supply amp or you'll need to offset the output from your bridge.
