Hi there!
Am new to this forum and thought to take this opportunity to ask for your opinion regarding purchases of components.
Have got hold of 2st engines:
1: 22VDC 250W 10.5A approximately 3800RPM. (Electric wheelchair).
2: 24VDC 30W 1.25A 240RPM. (In principle, wipers).
I want to be able to connect them to the wall outlet (230VAC) and has therefore been recommended these two PSU's at an online store:
1: USP-350-24 -> http://www.meanwell.com/search/usp-350/USP-350-spec.pdf
2: S-40-24 -> http://www.meanwell.com/search/S-40/S-40-spec.pdf
Do you think these are good options, or is there something more suitable?
I also want to be able to regulate the speed of both engines separately (0-100%) and had therefore imagined 2pcs 24VDC speed controllers, but I have a hard time finding something suitable to both. If possible, I also see that the knobs are not attached directly to the circuit board, I prefer a cord between for easy placement in a controller.
What do you think, is there anything to recommend?
I am also puzzled about heat generation, everything will sit mounted in a closed "box" of approximately 30x30mm. When in use, it will be running about 1-2h per occasion.
Right now, I will not tell you exactly what it is I'm building (some can probably be guessing what it is).
For the curious, I intend to present a finished model in the end incl. drawings.
