Made a PSU recently then figured out if I use a NPN TIP2955 Transistor, I could possibly boost the current towards 4 or 5 Amp instead of around 1.5A.
1. Is the below schematic the correct way to wire this thing?
2. Where marked, would there be a certain toggle switch capable of turning the boost on/off?
3. What type of switch? I've been looking at DPDT or SPDT and cant figure out for the life of me where to send each poles output... I thought a DPDT with the second output to run nowhere, would work?
4. Do I need to disconnect Base also and not just C + E?
It's been a long day..!
