PSU power cons.
Discussion in 'General Electronics Chat' started by Shagas, Jan 5, 2014.
  1. Shagas
    Thread Starter Active Member
    May 13, 2013
    802
    74
    Hello
    The title was supposed to be "excessive PSU power consumption" but for some reason I was unable to post with that title.
    I've recently recieved my dormitory electric bill of 30euros for last month and i've decided to investigate as to what is eating all that power.
    After sticking a cheap 6907 "power calculator" in between different appliances i've found that my Pc takes up 5-7watts when it's off which is reasonable (isn't it?) since it has a standby power mode.
    But what surprised me is that when the pc is on it takes up about 130 Watts of power! And that's when not running any programms, just sitting there on the desktop.It jumps up to 160-170 when doing basic things like web browsing.
    The pc is almost 4 years old and after some calculations I estimate that it has seen 17000-20000 working hours.
    I won't go into details of the spec of the PC but the basics are :
    - 3.2 Ghz 4-core processor
    - 1M graphics card
    - Some decent (at that time) motherboard
    - 1terrabite HDD
    - 1000 WATT power supply
    I have a suspicion that the power supply is eating alot of power for no good reason.
    Is it possible for the efficiency of an ATX or similar switching power supply to drop after tens of thousands of hours of use?
    Should I open it up and check the Electrolytics first?
    I am going to post a similar thread on some computer forum to see what
    people more experienced with computers are going to say but I want to hear
    an opinion from an electronics point of view aswell.
    The power supply is a 1000Watt coolmaster silent pro.
    Ps. yeah yeah I know a 1000Watt PSU is too much but when I was putting my pc together I didn't know much about Pc's and took advice from a friend who recommended that I get a 1000watt psu.
  2. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    I suspect had you tested the P.S. when you got the PC, you would have found comparable results.
    I wouldn't expect that to be excessive?
    Max.
  3. Shagas
    May 13, 2013
    802
    74
    I haven't tested the PSU when I got the PC so I don't have comparable results. But my pc had been running at about 12 hours daily and I haven't been getting high power bills until lately so that's what proned me to check it out.
    Hmm you really think that 130 watts is reasonable?
    Where is it all going?
  4. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    LOL
    My video cards requires more power than that ...
  5. paulktreg
    Distinguished Member
    Jun 2, 2008
    622
    124
    Taking the efficiency of your power supply into account (85%) leaves your PC pulling about 110W.
    Sounds about right.
    #12 likes this.
  6. Shagas
    May 13, 2013
    802
    74
    Well yeah , i've also got a 200watt card but I didn't think that the quiescent power consumption would be so high.
    Well I guess there is nothing I can do about it
  7. Dr.killjoy
    Apr 28, 2013
    1,209
    157
    Right now I am using a ATI 5770 1gb and Also have a Ati HD4870 512mb....
    Remenber too
    4 core Proccessor- 95 or more watts
    Video card-150 or more watts
    And the rest of the hardware pulls power and also you cooling system too
  8. PackratKing
    Jul 13, 2008
    850
    216
    " Paranoid Pete " sez... It's conspiracy and collusion of the power conglomerates to rip off the power consumer... :D
  9. Little Ghostman
    Member
    Jan 1, 2014
    294
    97
    dont use standby mode! when you start up kill off any processes you dont need, make sure you dont have silly programs that start when the pc starts. keep the start up as lean as you can, then just start the programs as you need them. have a good look at how many background programs and processes are running, stop any you dont need at the time. It all adds up in the end.
    Shagas likes this.
  10. #12
    Nov 30, 2010
    16,665
    7,313
    paulk went up the road I was thinking. The more excess capacity you have, the more waste at idle loads.
  11. Shagas
    May 13, 2013
    802
    74
    Yeah I was thinking the same thing.
    Also I think that I have too many unnecessary idle processes running.
    I compared my quiescent power consumption with a guy's down the hall
    and he has about 95 watts quiescent and a much more powerfull(much more recent) pc than I do.
