ok so finally got my parts list compiled for my First Power Supply.
One of the parts i got is a 3 in 1 Display (voltmeter,Clock,Temperature)
i basically only wanted it for the Temp and Volt but a clock is nice too.
Problem is.. Wiring it up.. it has 3 cables
Red: Power Supply +
Black: Power Supply -, Measure -
Green: Measure +
I know that the Black and Teal Cables go for Measuring. But where do i put the + Power Cable (red)..
I know it Cant be after Regulator, because it requires a minimum of 7volts.
But does it matter if i connect it before or after the capacitors?
Here is the Layout i am using (got it from the Make Website)
Red: Power Supply +
Green: Measure +
