pspice
Discussion in 'Electronics Resources' started by beem, Oct 28, 2013.
  1. beem
    Oct 23, 2013
    6
    I don't know why the circuit which is attached to this post, doesn't
    work as differential amplifier in "Pspice software" when both of the AC voltage sources are "1v " ?
  2. crutschow
    Mar 14, 2008
    13,505
    3,382
    A differential amplifier amplifies the differential (difference) signal between the two inputs. It ignores common-mode signals (same phase), which is what you appear to be applying. Invert the phase on one of the sources (by 180° or by inverting the connection) and you should see an output.
    Note: Please don't do multiple posts on the same subject.
