1. chemicalconsulting
    Apr 20, 2011
    I'm trying to evaluate a student version of PSPICE. I put a resistor across a battery and ran the simulation. The result was "Error: Node X is floating". The No-Help-Whatsoever feature said something to the effect of "fix the probelm and try again". Does anyone that uses PSPICE know what this cryptic and unexplained message mean?
  2. guitarguy12387
    Apr 10, 2008
    Pictures, Pictures!
    I haven't used PSPICE in years... but is there a way to dump the SPICE file? That will help alot too. Post that if you can figure it out.
    You probably need a ground node, too...
    Also, I doubt this is the issue with PSPICE... but with more powerful tools, I have experienced where the battery SYMBOLs are not necessarily tied to your power supply that you set up. You need to read documentation/tutorials to figure out how to set up a testbench or power supply/driving signals properly for the software that you're using
