Hi all,
Is find Demo version for Pspice SLPS Interface ?
Any information about it ?
Hi BertusHello,
Take a look here for more info:
http://www.ema-eda.com/products/orcad/tech.matlabsimulink.aspx
Bertus
Hi kingdano,
Do you have it ?
If you have any tutorial about it share me (please)
Hi kingdano,i do not have it at work, but i am working on bringing it to the company.
from what i know of the software you start by modeling your ideal system in the simulink environment - then you can simply drag and drop in an "SLPS" simulink block - link it up to a PSPICE schematic (which i dont know the details of, the interface could be time consuming and hard, but i simply dont know) and it will co-simulate the simulink system, passing information to the SPICE engine and receiving the data back from it to pass to other simulink blocks.
you can also do a similar thing with VHDL/Verilog files in Simulink - and you can see how the system will run with an actual HDL file simulating in a simulink system.
i am a big proponent of system simulation, and simulating everything to death so to me its a very powerful and useful tool. if you are also of the design flow mentality of:
design - simulate - build and test - debug
you will probably find the tool to seem useful.
if you are of the "old school" of
design - build and test - debug - build and test - debug....
you may not see the usefulness.
hope that helps
dan
Thank you manyour best bet is to follow up with cadence
sorry i couldnt be of more help
by Aaron Carman
by Jake Hertz
by Duane Benson
by Duane Benson
