PSpice simultion
Discussion in 'Homework Help' started by thisonedude, Aug 19, 2014.
  1. thisonedude
    Apr 20, 2014
    52
    I keep getting a job aborted when i try to compile my pSpice file. Can anyone tell me what i am doing wrong? This is my code:
    ** Part4
    Vi 1 0 AC 1
    Rl1 1 2 10k
    Rl2 2 4 10k
    Cl 2 4 0.01u
    X1 0 2 4 NOpamp
    Rh1 4 5 10k
    Ch 5 6 0.1u
    Rh2 6 7 10k
    X2 0 6 7 NOpamp
    .subckt NOpamp 1 2 3
    Ri 1 2 2MEG
    Ei 4 0 1 2 1
    R 4 5 1
    C 5 0 0.0383
    Eo 6 0 5 0 200K
    Ro 6 3 75
    .ENDS
    .AC DEC 100 10 10M
    .PRINT VDB(7), VP(7)
    .OPTIONS POST
    .END
    And what i am tryig to construct is the following circuit: (Check attachment)
    Any help would be appreciated!
      File size:
      211.2 KB
      23
  2. crutschow
    Mar 14, 2008
    13,508
    3,384
    Does it give you an error message?
  3. thisonedude
    Apr 20, 2014
    52
    The only error message I get Is "job had aborted"
    Does my spice code look correct at all? Is it maybe my parameters when I try to ask for an AC analysis?
  4. thisonedude
    Apr 20, 2014
    52
    This is the error message:
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    You have the pin order on the subcircuit screwed up...
  6. thisonedude
    Apr 20, 2014
    52
    How should it go? Shouldn't it be 1 2 3 , 1 being + 2 being - and 3 being the output?
  7. Alec_t
    Sep 17, 2013
    5,979
    1,138
    I don't use Pspice, but in LTspice ".AC DEC 100 10 10M" would be wrong. The 10M would be 10Meg (unless you really do want the analysis to start at 10milliHertz!).
    Don't the opamps need a supply voltage?
  8. MikeML
    Oct 2, 2009
    5,451
    1,066
    Here is what works in LTSpice. I show you the netlist that LTSpice created based on the graphical schematic that I started with. You should be able to run that in PSpice.
    The important thing is that you figure out what is wrong with your netlist. (There is an error)
  9. thisonedude
    Apr 20, 2014
    52
    Thank you all for all the help!!! So I figured out my mistake. Instead of having 10M I Should have had a smaller stop value. My start value was greater than my stop value. Thanks all again!
