I'm using version 9.2 for Orcad but I doubt it makes a huge difference for newer versions.
The problem is attached.
I am able to draw the schematic on pspice. I create an AC Sweep simulation with
starting frequency: .01
ending frequency:1,000,000
Logarithmic Decade:100.
I run the simulation and I can do part(a) easily because the resistor is connected to ground. I add trace DB(V(R1:1)). Plot a new y-axis and then add trace VP(V(R1:1)).
My problem is, I don't know what the expression is for part(b) and part(c).
Is VDB across the inductor,
DB(V(L1:1) -V(L1:2))
or is it
[DB(V(1:1)) - DB(V(L1:2))]
or am I doing everything wrong?
or is it
