Pspice simulation problem
Discussion in 'Electronics Resources' started by laguna92651, Sep 13, 2008.
  1. laguna92651
    Thread Starter Active Member
    Mar 29, 2008
    101
    I have a simple circuit 2v supply R and Diode in Pspice that I'm trying to run a simulation on. I get the following message when I press run.
    "This action cannot be completed because the other program is busy. Choose 'Switch To' to activate the busy program and correct the problem."
    I have no idea what the other program is they are referring to. When I choose 'Switch To' button my Vista Start menu comes up.
    The Pspice forum doesn't seem to be too active, does anyone know of a more helpful Pspice forum.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What program are you using for SPICE simulations?
    The first thing I would suggest doing is to save your simulation, shut down completely and then re-boot your computer. Then try it again.
    There may be another copy of the simulator running in another window and you just don't see it, or memory may be corrupted. Tough to say. Re-booting often cures many ills.
  3. laguna92651
    Mar 29, 2008
    101
    Thanks, I already tried that. I'll uninstall and reinstall and see if that helps.
  4. laguna92651
    Mar 29, 2008
    101
    Haven't reinstalled yet, but got pspice running on my laptop.
    Simulation works on laptop. I have a simple R Diode circuit to simulate. I want to change some of the characteristics of the diode, Isat and V diode turn-on. I'm using a 1N914, where do I change characteristics? Tried the propety editor, but don't see any place there to make change.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I have no clue, since I don't know what PSPICE program you're using.
    SPICE was originally programmed on a mainframe computer. PSPICE is basically similar algorythms that were ported over to run on a personal computer. There are many, many different PSPICE circuit emulators. The SPICE directives they use are all very similar if not identical, but the underlying software is coded differently.
  6. nanovate
    Distinguished Member
    May 7, 2007
    665
    Did you use a diode from the breakout library (assuming you are using OrCAD)?
  7. laguna92651
    Mar 29, 2008
    101
    I am using OrCad the term Breakout library doesn't sound familiar. but I am use a diode, 1N914, from the supplied librar, Eval library.
  8. nanovate
    May 7, 2007
    665
    There should be a breakout library where the models are editable. the other option is to creat a new part with your custom model.
    I haven't used OrCAD in awhile. LTSPICE/SwitcherCAD from Linear Technology is much easier to use in this respect-- just drop the SPICE model down on schematic and point to it.
  9. laguna92651
    Mar 29, 2008
    101
    I'm brand new to pspice, just installed. You don't have to know the actual name of the library do you?
  10. laguna92651
    Mar 29, 2008
    101
    I found the breakout library, but don't see how to modify Isat and Vcut-in when I go to the Edit Properties. Any ideas?
  11. n9352527
    Oct 14, 2005
    1,198
    Have a look at this page http://www.allaboutcircuits.com/vol_3/chpt_3/14.html. The model parameters do not exactly correspond to datasheet parameters. You could try changing a few parameters, like IS, N or RS so that you have a IF against VF curve according to your requirement, hovewer you have to realise that other characteristics of the diode would also be different.
    Furthermore, each parameters in the model might seem relate to or describe a physical semiconductor property, but in practice most models are developed with curve fitting methods instead, so changing one parameter might not result like what you expect.
  12. laguna92651
    Mar 29, 2008
    101
    Wonderful, that is exactly what I was looking for next.
    In the SPICE parameter list given it doesn't define VJ, I assume VJ is the cut-in voltage to turn the diode on, is that correct?
  13. n9352527
    Oct 14, 2005
    1,198
    VJ is the junction potential. As I wrote in my earlier post, there's rarely one to one correlation between a SPICE parameter and actual physical characteristic. Changing VJ will change the cut-off voltage, but also a lot of other characteristics.
    The best method to achieve what you required, as outlined in the referenced page, is to change the SPICE parameters and re-simulate and compare the transfer curve against the one that you want. Not a fun processes, you might need to perform a lot of iterations to achieve suitable transfer curve. Note that this method has to be done separately for AC parameters if you also simulate AC response.
    Try changing IS, N, RS and VJ and see the resulting curves.
