Pspice Simulation Problem : The part/device cannot be simulated
Discussion in 'Programmer's Corner' started by feiz94, Apr 12, 2016.
  1. feiz94
    Apr 12, 2016
    I tried to simulate a schematic on Pspice. But when I run the simulation (transient), I got some Errors saying that : The part/device cannot be simulated..
    I got a green circle on the OP27. I tried to change this device with another OPamp 27 from other libraries but it didn't work (Please see the Printscreen)
    Any one has an idea to solve this Problem?
    Thank you in advance.
  2. massimo.del.rosso
    Mar 10, 2016
    Are You sure that the Pspice model of the OP27 is ok ?
    Try this check:
    Select the OP27 , then right click with the mouse on the OP27 , then select "edit Pspice model"
    Do You get the right pspice model for the op-amp ?
  3. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Are you sure you have the model file in the correct folder where Pspice can find it?
    massimo.del.rosso likes this.
  4. SLK001
    Nov 29, 2011
    851
    243
    Try a different opamp model. The "green circle" usually indicates an open connection.
  5. massimo.del.rosso
    Mar 10, 2016
    Hello, are you there ?
