Pspice Simulation issue
Discussion in 'General Electronics Chat' started by Orien Walker, Aug 3, 2016.
  1. Orien Walker
    Aug 1, 2016
    27
    Using a lite version of pspice and the entire simulation section is deactivated and it wont allow me to simulate anything. does the lite verson not allow for actual circuit simulation?
  2. SLK001
    Nov 29, 2011
    851
    243
    It will simulate, but you have to use the parts that PSpice provides in the lite version.
  3. Orien Walker
    Aug 1, 2016
    27
    Ok, i imported a model of the chip I'm trying to simulate from TI's website. is that whats causing the issue?
  4. SLK001
    Nov 29, 2011
    851
    243
    Is the TI chip model in the libraries supplied by PSpice?
  5. Orien Walker
    Aug 1, 2016
    27
    no, i had to download the file from TI after the fact. It was not part of the original pspice libraries.
  6. crutschow
    Mar 14, 2008
    13,498
    3,374
    Try LTspice.
    It's free and allows addition of outside models of any kind.
    But I'm surprised that you PSpice is completely deactivated because of an added model.
    You may have a different problem.
    Does it work if you remove the model?
  7. Orien Walker
    Aug 1, 2016
    27
    I've tried LTspice, it doesnt have the option to add in the module i need. it comes with a lot of LT modules, but nothing from TI. and i cant find a LTsoice compatible module for the device i need. It might be another problem, but i used pspice in school and never had this issue. i started a new schematic, added all my parts, connected my circuit, assigned values and it wont allow me to run it, save it or interact with the schematic on any analytical level.
  8. crutschow
    Mar 14, 2008
    13,498
    3,374
    What is the module you can't add to LTspice?
  9. Orien Walker
    Aug 1, 2016
    27
    A TI LM3401 Hysteretic PFET Controller for High Power LED Drive
  10. Alec_t
    Sep 17, 2013
    5,972
    1,135
    The TI model for that is encrypted :(.
  11. Orien Walker
    Aug 1, 2016
    27
    What does that mean Alec? it allowed me to import it into my schematic and wire it up. is the encryption why i cant sim anything?
  12. Alec_t
    Sep 17, 2013
    5,972
    1,135
    I don't use Pspice, so not sure what the encryption does there. Can't work out how to use the model with LTspice though.
  13. Orien Walker
    Aug 1, 2016
    27
    what software would you suggest for circuit simulation and PCB design?
  14. Orien Walker
    Aug 1, 2016
    27
    I'm stuck between eagleCAD and using its bridge to LTspice or the OrCAD pspice suit.
