PSpice Model Editor Fixed Parameters
Discussion in 'Electronics Resources' started by poynt99, May 14, 2015.
  1. poynt99
    May 14, 2015
    Does anyone know PSpice Model Editor well?
    The background to the question, when you are creating a new model (MOSFET) from a data sheet, Model Editor (ME) has a window with the LEVEL 3 parameters at the bottom, and a window in the top right with several tabs with curves; Transconductance, Transfer Curve, Rds(on), Rev. Drain Current etc.. When producing curves, there are always 1 or 2 of 3 parameters that are swept, while one is held constant. For example, with a transfer curve, VDD is held constant, Vgs is swept, and Id is measured, and Vgs vs. Id is plotted.
    My question is this: ME does not allow you to enter a value for the fixed parameter, VDD in my example above. If it does have a field somewhere, I have not been able to find it. The same goes for all the other tabs I mentioned above, there is no where to enter the fixed value. So while trying to match the curves with actual data sheet curves or actual bench-swept curves, how can I do it if I don't know what I am matching to?
    See attached pic.
    Thanks,
    .99
