Pspice CMOS Inverter
Discussion in 'The Projects Forum' started by Runs212, Sep 12, 2015.
  1. Runs212
    Mar 12, 2015
    55
    I'm trying to design a cmos inverter on pspice (just started using it this week) but I'm not quite getting the correct waveform. Below pictures shows my schematic and output graph. What am i doing wrong here?
  2. #12
    Nov 30, 2010
    16,705
    7,358
    What is wrong about the wave form? The fact that it's going to negative 5 volts and there is no such supply voltage?
  3. Runs212
    Mar 12, 2015
    55
    Yes, I expect it to switch from 0 to 5v.
  4. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Put your V- probe be on the ground rail.
  5. WBahn
    Mar 31, 2012
    18,093
    4,920
    When the voltage on the input node is 0V and the voltage on the output node is 5V, what is (Vout - Vin) equal to?
    When the voltage on the input node is +5V and the voltage on the output node is 0V, what is (Vout - Vin) equal to?
  6. eetech00
    Jun 8, 2013
    685
    118
    I agree with Alex_t....:cool:
  7. WBahn
    Mar 31, 2012
    18,093
    4,920
    Alex_t's suggestion certainly solves the problem. I'm just trying to get the TS to understand WHY they are seeing what they are seeing.
  8. md yasir
    Sep 14, 2015
    16
    use pulse of
    v1=0
    v2=5v
    td=0
    tr=0
    tf=0
    pw=0.5m
    per=2m
  9. WBahn
    Mar 31, 2012
    18,093
    4,920
    How will that help?
    Having 0 rise and fall times can cause problems for the simulator. But even if it doesn't, how does this help answer the TS's question?
  10. md yasir
    Sep 14, 2015
    16
    i just tried @WBahn in pspice 9.2 student version
  11. WBahn
    Mar 31, 2012
    18,093
    4,920
    So? Again, how does that help the TS solve their problem. Their simulation was running fine. They were just having trouble understanding the values it was producing.
  12. Runs212
    Mar 12, 2015
    55
    It was resolved. I probe should have placed at gnd. You notice i placed V- at the 5V source. Thanks everyone for your contributions and clarifications.
