PSPICE circuit Problem
Discussion in 'Homework Help' started by bumclouds, May 18, 2008.
  1. bumclouds
    Thread Starter Active Member
    May 18, 2008
    82
    Hey guys,
    I'm trying to simulate the below circuit:
    I'm drawing it up in PSPICE for an AC sweep and transient analysis, but its producing really strange results which contradict the transfer function I have calculated on paper several times.
    Is there anything you can see that is immediately wrong?
    PS: Beta = 100
    Thanks!
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    What is F4?
    Is it an optically coupled transistor? Then it has no power supply and it has no load resistor.
  3. bumclouds
    May 18, 2008
    82
    ^ F4 is a current-controlled current source of gain=100.
  4. JoeJester
    Apr 26, 2005
    3,392
    1,211
    You mean something like this?
  5. bumclouds
    May 18, 2008
    82
    i found a solution to my problem. it wasn't how i was drawing the circuit, it was that my AC sweep needed to go back before 1 rad/s in order to detect the first pole.
    PS: JoeJester what exactly is that circuit that you've provided and how come it's exactly the same as the one in my assignment?
  6. JoeJester
    Apr 26, 2005
    3,392
    1,211
    My circuit is your circuit.
    You had a Current Controlled Current Source with a gain of 100. It used the current in the capacitor (Ib). I used the information you provided.
    In your drawing you just indicated Ib and the CCCS was beta Ib. The CCCS symbol used in my spice is probably what confused you, as it is required to sample the current (left side of the symbol) to provide the output.
