* V2.0 Helmut Sennewald 02/22/04
* The Rechargable Battery
* Possible Parameters
* VCELL nominal cell voltage in volts, e.g. 1.2
* CAPAH cell capacity in Ah(ampere*hours), e.g. 1.8
* R_SER series resistance in Ohms, e.g 0.2
* SOC state of charge (0..1, 0=empty, 1=full)
* CHEFF charging effeciency, e.g 0.7 means you need 1/0.7 times the
* ampere*hours to charge fully
* SELFDC self discharge per hour, e.g. 0.00028 if 20%/per month
* I started with an old article from S.C.Hageman about a SPICE model for
* NIMH batteries. It's the model "NIMH" - PSpice Nickel-Metal-Hydride
* battery discharge simulator. Optimized for 4/5A and AA Standard Cells
* and discharge rates from 0C to 5C. It's for discharge only.
* First I did some little changes on this discharge model.
* Later, I started with further development to include a charging model
* the battery too. The result is the new model NIMH_AA.
* Ext+ Ext- Soc Rate_d
* | | | +-- Instantaneous discharge rate, 1V=C
* | | +------ State of battery charge 1V=100%
* +-------+----------- +/- Cell connections (Floating)
.SUBCKT NIMH_AA Ext+ Ext- Soc Rate_d
.PARAM VCELL=1.2
.PARAM CAPAH=1.8
.PARAM R_SER=0.2
.PARAM SOC=1
.PARAM CHEFF=0.7
.PARAM SELFDC=0.00028
.IC V(Charge)={SOC}
.NODESET V(Charge)={SOC}
.PARAM R_DIS={VCELL/(SELFDC*CAPAH)}
R_Cell Ext+ Cell+ {R_SER}
V_Sense Ext- Cell- 0
R_dis Cell+ Cell- {R_DIS}
* Charge to voltage translation with E-TABLE
* The last table entry (1.1 -10) together with the clamped reverse voltage(D2)
* defines the battery voltage in reverse mode. If this entry is omitted,
* then the battery will clamp to zero volts.
E_Cell Cell+ Cell- TABLE { V(SODC) } =
+(0.0 1.3346) (0.0293 1.3042)(0.0426 1.2942) (0.0689 1.2841)
+(0.13 1.2733) (0.436 1.2633) (0.512 1.2532) (0.580 1.2432)
+(0.646 1.2331) (0.702 1.2231) (0.7583 1.2130)(8.0324E-01 1.2030)
+(0.831 1.1929) (0.851 1.1828) (0.908 1.1425) (0.948 1.0919)
+(0.980 0.987) (0.99 0.9352) (0.995 0.8272) (0.996 0.741)
+(0.997 0.647)(0.998 0.514) (0.999 0.33) (1.0000 0.0) (1.1 -10)
* Actual rate of discharge by external load.
* E.g. 0.2 means a full battery battery would last 5hours(=1/0.2).
E_Rate N001 0 VALUE = { IF( (I(V_sense)>0 & V(Cell+,Cell-)>0),
+ I(V_Sense)/CAPAH, CHEFF*I(V_Sense)/CAPAH ) }
R2 N001 Rate_d 1
C1 Rate_d 0 1
* State of charge is actually just a 1 to 1 transform of "Charge"
E_Rate1 Soc 0 TABLE { V(Charge) } = (-1,-1) (1,1)
* Higher capacity for discharge current below 0.2*C
E_LowRate LowRate 0 TABLE { V(Rate_d) } = (0,0) (0.001,0.15) (0.1,0.1) (0.2,0)
R3 LowRate 0 1G
G_LowRate 0 Charge VALUE = { IF( (I(V_sense)>0 & V(Cell+,Cell-))>0,
+ V(LowRate)*I(V_Sense), 0) }
* Lower capacity for discharge current above 0.2*C
E_LostRate LostRate 0 TABLE { V(Rate_d) } = (0.2,0.0) (1.0,0.1) (5,0.2)
R5 LostRate 0 1G
G_HighRate Charge 0 VALUE = { IF( I(V_sense)>0 & V(Cell+,Cell-)>0,
+ V(LostRate)*I(V_Sense), 0) }
* The charge model
* Overcharge and discharge clamped with diodes
C_CellCapacity Charge 0 { 3600 * CAPAH }
R1 Charge 0 1MEG
V2 N003 0 0.993
D1 Charge N003 DFULL
D2 0 Charge DREV
G_DisCharge Charge 0 VALUE = { IF( I(V_Sense)>0 ^ (V(Cell+,Cell-)<0),
+ I(V_Sense), I(V_Sense)*CHEFF) }
* State of Discharge = 1-SOC
E_Invert SODC 0 TABLE { V(Soc) } = (-1,2) (0,1) (1,0)
R4 SODC 0 1G
.model DFULL D(Is=1e-6 N=0.02)
.model DREV D(Is=1e-8 N=0.02)
.ends
