PSIM Newbie! Starting/Charging system
Discussion in 'The Projects Forum' started by sbarnas90, Nov 23, 2015.
  1. sbarnas90
    Nov 23, 2015
    Hello all, I am looking for some help on creating a starting/charging system. im looking to simply simulate a typical 12v system that is used in cars. any help would be great.
    thanks
  2. R!f@@
    Apr 2, 2009
    8,792
    771
    Welcome to AAC
    Is it too much to provide all the information before asking ?
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    I have posted some running simulations of automotive charging systems here
    and here.
    You will have use LTSpice or convert the sims...
  4. sbarnas90
    Nov 23, 2015
    hello! well i need to simulate a 12 volt dc charging system with a battery and generator/alternator to charge the battery. Next i need to add a 12volt motor to run of the the battery... I understand how his looks, i understand how it works. I'm not family with PSIM and am confused on how to assemble this circuit. that is what i need. If somebody could assemble a simple circuit with a Battery,Generator and Starter motor(all 12volt DC) that would be very helpfuk to me.
    Thanks!
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    This sounds like homework or a lab assignment...?
  6. sbarnas90
    Nov 23, 2015
    Personal/Work/Class. Im a mechanic and trying to present a breakdown of a charging system. I'm not asking for somebody to a run a simulation. I'm simply asking if somebody can assemble the components for me, this way i can build the circuit and make changes.
  7. MikeML
    Oct 2, 2009
    5,451
    1,066
    Did you follow my links?
