PS3 PSU HELP no standby light
Discussion in 'Technical Repair' started by HEINRICHF, Sep 10, 2016.
  1. HEINRICHF
    Sep 10, 2016
    Hi there hope someone can help i have ps3 console with no standby light the silicon bridge rectifier is faulty can someone tell me how many volts must the replacement rectifier be
  2. wayneh
    Sep 9, 2010
    12,374
    3,225
    How do you know your rectifier is bad? Can you read any markings on it?
    The current rating is crucial. It's likely rated to double your line voltage or so, but you need to replace it with one with the same or higher current rating. Look around for other components it might have taken down with it.
  3. HEINRICHF
    Sep 10, 2016
    i have replaced the capacitors it did work for few minutes but it died again thats why i want to replace capacitors and voltage rectifiers thers also a diode sb360 thats giving 0.2 on multimeter other forums syays diode should be 0.5 is that correct and the voltage rectifier will 1000v or 750v be ok for ps3 psu thanks
  4. Alec_t
    Sep 17, 2013
    5,967
    1,135
    According to the datasheet 0.2 is correct for a diode current <0.1A. At 3.0A the diode would drop 0.74V.
    If in doubt about a component property, always consult its datasheet.
    wayneh likes this.
  5. HEINRICHF
    Sep 10, 2016
    HI the rectifier is US6K 80R i have watch few guys on youtube how to check rectifiers Tampatec video i use
  6. wayneh
    Sep 9, 2010
    12,374
    3,225
    That bridge is rated 6A and 800V. Replace it with a bridge rated at least that high on both measures, if you're convinced it's bad.
  7. HEINRICHF
    Sep 10, 2016
    Hi just one last thing i have auto raging digital meter the diode sb360 give exact reading of 0.160 is that too low.
  8. wayneh
    Sep 9, 2010
    12,374
    3,225
    No, the apparent voltage drop depends on current and your meter is supplying very little. The low number might be suspicious but it doesn't tell you anything for certain.
