ps2 connector data ?
Discussion in 'Computing and Networks' started by Mathematics!, Mar 22, 2010.
Thread Status:
Not open for further replies.
  1. Mathematics!
    Thread Starter Senior Member
    Jul 21, 2008
    1,022
    I am wondering how ps2 connectors for keyboards delimit a logical zero from a logical one.
    For example if I hooked up the ps2 connector pins to a MCU how do I know when the keyboard is sending a one or a zero.
    Basically from the pinout and this
    http://pinouts.ru/Inputs/KeyboardPC6_pinout.shtml
    I know that every time you press a key on the keyboard an 11bit packet of data is send 8 bits of it being the ascii code of the given key pressed.
    But I don't understand what voltage is a logical one and what is a logical zero? What to do with the clock pin / data pin to get the actually 101010010001100 data ...etc
    I know I just connect the ground pin to ground and VCC pin to 5volt dc supply but as for the clock or data pins do I just connect them to two seperate MCU pins...?
    Thanks for any help
    This should be to hard
  2. rjenkins
    Nov 6, 2005
    1,015
    69
Thread Status:
