PS/2 Port Problem
Discussion in 'General Electronics Chat' started by Peter_England, Jul 4, 2013.
  1. Peter_England
    Jun 29, 2013
    73
    I am facing a PS/2 port problem on Intel DG31PR Motherboard how to trace the circuit problem ? please give some useful information .
  2. nerdegutta
    Dec 15, 2009
    2,565
    805
    Please give some more information:
    1) What kind of problems?
    2) What have you done?
    3) What do you think is causing the problems?
  3. Peter_England
    Jun 29, 2013
    73
    Thanks nerdegutta I have removed decoupling caps for Data line and Clock line but no luck actually num-lock toggles but no working of keyboard means not getting in bios settings or any keyboard activity i have checked with two keyboards so no keyboard fault itself . thanks .
  4. nerdegutta
    Dec 15, 2009
    2,565
    805
    Are you sure the keyboards work? Tried on another computer? Did this suddenly happen, or were you fiddling around? Have you tried hard resetting the motherboard?
  5. Peter_England
    Jun 29, 2013
    73
    yes i changed bios also and the keyboard is working fine in other systems . thanks.
  6. nerdegutta
    Dec 15, 2009
    2,565
    805
    Changed bios...? To one exactly the same...?
  7. Peter_England
    Jun 29, 2013
    73
    yes from another working motherboard of Same type . thanks.
  8. nerdegutta
    Dec 15, 2009
    2,565
    805
    What happens when you turn it on? Does the motherboard go through the POST?
  9. Peter_England
    Jun 29, 2013
    73
    yes it goes through post .
  10. nerdegutta
    Dec 15, 2009
    2,565
    805
    I'm out of ideas, right now. I might come back...:)
  11. Peter_England
    Jun 29, 2013
    73
    Ok thanks. No problem.
  12. sheldons
    Oct 26, 2011
    616
    101
    have you checked the data lines are changing when a key is pressed .....you obviously have a fault where the keyboard control lines for whatever reason are not being read-is there a signal from the board to the keyboard key scan wise....
    Peter_England likes this.
  13. Peter_England
    Jun 29, 2013
    73
    Thanks Sheldons , please tell how to check that signal pls tell .
  14. €Hunter
    Jul 6, 2013
    33
    Not sevicable. Highly specialized. Trade secrets and the right gear the only hope.
  15. Peter_England
    Jun 29, 2013
    73
    Is that need an Oscilloscope ?? or what ? Please give some idea .Thanks.
  16. €Hunter
    Jul 6, 2013
    33
    Tell me that you're an ex employee of the company that made it.
  17. €Hunter
    Jul 6, 2013
    33
    Few 1,000 flight hrs of real time experience repairing motherboards?
    Go buy a lottery ticket you stand a better chance.
  18. Peter_England
    Jun 29, 2013
    73
    No i am not an ex employee of any one of the companies you think. thanks. pls help me i am stuck at Intel DG31PR motherboard that i need to repair and give back to client. the rest motherboard is working good . please help.
  19. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Why not just use a USB keyboard?
  20. €Hunter
    Jul 6, 2013
    33
    Hope you find some help. I mean there is a slight chance that I am wrong. Perhaps an expert or two can shed some light.
