Yes. Mount your components on the side without copper. On the copper side, you can solder to the pads. Then, use the excess leads or solid hook-up wire (e.g., 22 to 26 ga.) to make connections between components.
My experience with prototype boards has lead me to avoid the use of vector boards that have pads on one side only. I have found the pads tend to be easily delaminated unless the greatest care is used in the soldering process.
