Protoboard and Diy PCB
Discussion in 'General Electronics Chat' started by Dr.killjoy, Nov 17, 2013.
  1. Dr.killjoy
    Apr 28, 2013
    1,210
    158
    How many of you use protoboard or stripboard or somthing similiar????
    Also today I was walking my local fleamarket and someone gave a sheet of 8"X11" clad board and I was thinking about building my first curcuit board with it ... But my question is what does you use to cover the copper traces? ??? I was thinking about coating the copper traces with solder or using that silver plate like solution .. The solder mask just seems like a lot of work for me ..,.
    Jason Sr
  2. MaxHeadRoom
    Jul 18, 2013
    10,855
    2,525
  3. gootee
    Apr 24, 2007
    447
    50
    Back when I did a lot of prototyping, at home, I eventually started just making a PCB for each iteration, much of the time. I could go from computer screen layout to finished PCB in under an hour. (http://www.fullnet.com/~tomg/gooteepc.htm , but it's now way-outdated; also see the Homebrew_PCBs group at yahoogroups.com )
    Strip-board and other PCB-type proto-boards are very good, too. But if you get to the point where layout matters, then layout matters and you might as well make a PCB so you're not guessing as much.
    I never bothered coating prototypes, since they weren't around long-enough.
    For longer-term use, there was a product called TINNIT, that seemed to work very well. It was two powders that were mixed, heated a little in a microwave I think, and then dipping the board for a few minutes coated all of the copper with shiny tin (or something like it). If you just want to prevent oxidation, I guess a lot of different types of coatings could work.
  4. sirch2
    Jan 21, 2013
    1,008
    351
    I use both stripboard and PCBs depending on what I am doing. The free version of VeeCad is reasonable for stripboard layouts.
    Like others have said, I generally don't coat PCBs but if I do need to, I just give it a spray with clear car lacquer. It the etching is a bit rough and the board is fairly simple I do sometimes run solder over the tracks.
  5. Dr.killjoy
    Apr 28, 2013
    1,210
    158
    Right now I am using some German company protoboard program that I really like ..
    Thanks Guys for info
    Jason SR
  6. adamclark
    Member
    Oct 4, 2013
    472
    6
    which one?
  7. Dr.killjoy
    Apr 28, 2013
    1,210
    158
    Blackboard circuit designer
  8. KMoffett
    Dec 19, 2007
    2,584
    234
    For one-offs or proof-of-concept, I use 0.1x0.1" one-pad-per-hole vector board. I do the schematic and PCB layout in ExpressPCB (free). In the PCB layout I do everything on multiples of 0.1" spacing, so it will match the vector board. I then use point-to-point wiring with stripped or insulated 32 Ga. Kynar wire-wrap wire, following the PCB layout trace locations. If I need two-sided to route traces, I just do both sides on the bottom with two different colored wire. I'm not into high frequency designs, so this works for me.
    Ken
  9. BobTPH
    Jun 5, 2013
    807
    121
    I have finally gotten a reliable PCB DIY process using a modified laminator and toner transfer. I think I can make a PCB about as fast as I could do a proto board considering how error prone the proto board wiring is.
    My modified laminator a cheapo from Harbor Freight. I replaced the 130C thermostat with a 160C and slowed the laminator down by making a uController circuit turn it on for 1/2 sec with adjustable off. 5 seconds off transfers the toner reliably in one pass with 0.01 inch traces and spaces coming out okay.
    Bob
    p.s. My only remaining problem is getting all of the toner to transfer reliably. I have tried almost every kind of paper and get the best results with the blue pastic transfer sheets designed for that purpose. But i still get holes in some traces and have to fix them with a very tiny paint brush and acrylic paint. If anyone knows an exact paper product that works better than this, let me know!
  10. MaxHeadRoom
    Jul 18, 2013
    10,855
    2,525
    I take it you presently have to know German to be able to use it, Ja?
    Max.
  11. Dr.killjoy
    Apr 28, 2013
    1,210
    158
    I know a little german but the website is german but the program run on english....
  12. panic mode
    Oct 10, 2011
    1,329
    305
  13. KMoffett
    Dec 19, 2007
    2,584
    234
    At least the person in the video could have connected the rectifier correctly to the transformer's secondaries....and added a filter capacitor. ;)
    Essentially that technique is what I do in ExpressPCB. The advantage of ExpressPCB is that there is a net list crosscheck between the schematic and the PCB. As the circuit gets more complicated, it saves a lot of errors on this type of wiring layout.
    Ken
  14. Metalmann
    Dec 8, 2012
    700
    223
    Thank you, Max.
    First time ever seeing that site, and some of their prices are better than Ebay.:cool:
  15. MaxHeadRoom
    Jul 18, 2013
    10,855
    2,525
