Proteus - Short pin to ground plane and PCB hole
Dritech
Joined Sep 21, 2011
901
Hi all,
I am using Proteus 8 to design a PCB using manual routing. I included a ground plane using the Zone Mode button. How can I short a single header connector pin to the ground plane? Also, I did an irregular shaped hole in the PCB using the 2D Graphics Arc Mode button. When the ground plane was not included, the hole apeared in the 3D view. When I included the ground plane, the hole did not appear (although it appeared as yellow line - board edge). What can I be doing wrong?
