Proteus oscilloscope is giving half the reading
Discussion in 'Electronics Resources' started by shikhar623, Jun 24, 2015.
  1. shikhar623
    Thread Starter Active Member
    May 9, 2009
    31
    I have connected a battery of 20 volt but the oscilloscope is showing the value of 5*2=10volt only . I have Attached a SS
    Please help me understand this.
  2. crutschow
    Mar 14, 2008
    13,472
    3,359
    Since the circuit is not shown there's no way to determine what the problem is.
  3. shikhar623
    May 9, 2009
    31
    It's a 20 v battery connected to oscilloscope..
  4. shikhar623
    May 9, 2009
    31
    That's is the only ckt. A 20v battery connected to oscilloscope..
  5. absf
    Dec 29, 2010
    1,493
    374
    Mine is displaying fine. Try with "VSOURCE" in "simulator primitives" and see if it works.
    Allen
  6. shikhar623
    May 9, 2009
    31
    Thanks Allen. It's working fine now. Wonder what was the reason of the error!
  7. absf
    Dec 29, 2010
    1,493
    374
    Not sure.... May be your Battery Properties has been modified.
    Did you try putting a Voltmeter across your Battery and see if the voltage indicated is correct?
    Allen
