Proteus DC supply help
Discussion in 'General Electronics Chat' started by Ankon, Apr 3, 2013.
  1. Ankon
    May 10, 2011
    6
    Hi.I have a problem using DC voltage in proteus.In the attachment photo you see dc voltage in proteus has only one side for wiring and that's the +ve side.but there is no -ve in there.but when I came to analyse this circuit I had to find the current through the -ve side of the voltage source to ground.If proteus voltage source is virtually grounded then that means current will be zero because ground to ground same potential.but there current must be 0.0025A . so please help
      File size:
      112.5 KB
      645
  2. absf
    Dec 29, 2010
    1,493
    374
    Did you try "Battery" or "VSOURCE"?
    Allen
    Ankon likes this.
  3. Ankon
    May 10, 2011
    6
    I didn't use BATTERY AND VSOURCE earlier. now I just used it and problem is solved.thanks a lot. While using current control current source in proteus input needs a transfer fucntion.How can I put 4A current source in proteus and how to give it a value?
