Protective Epoxy... removal???
Discussion in 'General Electronics Chat' started by midnitrcr, Nov 28, 2006.
  1. midnitrcr
    Oct 16, 2006
    I have a couple electronics items which I would like to repair, however, the faulty components are under black protective coatings and I can't get access to them or even identify what they are...
    Does anyone have any ideas on how to get this stuff off? (i already tried scratching it away) It looks like some sort of fiberglass material because it breaks off in little "hairs" which are very uncomfortable to get underneath your nail...
    I tried google, but couldn't even really find a good set of keywords other than "protective epoxy" and a couple others which went nowhere...
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Acetone will do the trick, but it also takes off paint and the epoxy in FR4 galss pc boards. Not to mention the explosive vapors. Be careful, and don't expect to be able to recognize the stuff underneath.
  3. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    They put that stuff on it to protect their "Intellectual Property". And it works.
  4. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Abandon hope all ye who remove black protective coatings. Even if you could get the stuff off your chances of identifying, obtaining, and replacing the custom ASIC underneath are nil.
  5. n9352527
    Oct 14, 2005
    1,198
    It depends on your budget. If you are prepared to pay big money, then it is possible. But I don't think it is worth it just to repair things. There are equipments that can strip those kind of coating/potting. Or companies that are able to do them.
