Protecting PCB from corrosion and oxidation
Stuntman
Joined Mar 28, 2011
222
This is what I have used
ACL 8690
Not much feedback other than I have not had a problem with the very few prototype boards I have done with it. What IS nice is it is very clear, so you can apply and still see destructive failures and may have a chance of removing the coating for a repair.
SgtWookie
Joined Jul 17, 2007
22,230
I suggest that wax, including altar candle wax, is not a good substitute candidate for conformal coat, as if the board has an overheat-type failure, the wax may vaporize and act as a source of fuel for a fire.
shortbus
Joined Sep 30, 2009
10,045
But since it was from an 'altar candle', wouldn't that be OK? A sacrifice to the circuit gods?
Stuntman
Joined Mar 28, 2011
222
+1
Had a prototype someone thought would be best to seal with wax. Ended up with oil soaking up boxes and the wax flaking off. I'd think about spray paint before I jacked around with wax.
ian field
Joined Oct 27, 2012
6,536
+1
Mine was a prototype that I anticipated needing to modify, probably several times.
As it turned out, the project worked first time, the biggest downside of using wax was that I didn't have suitable means to degrease the assembly.
The original was cobbled together on a strip of sheet aluminium heatsink from a scrap PC monitor, so it wasn't exactly tailored to fit the space next to the coil - that was my excuse to build again shaped to fit, and without any wax on it I was able to use a spray coating.
Unfortunately, the stuff I bought from Maplin didn't work as well as the wax!
