I am using two latching relays in an automotive application. The coils are rated for 12vdc and 25mA. Im wondering if it is okay to power the coils with the standard 12V electrical system or If I need to lower the amperage. SP2-L2-DC12V That is the part number. Also I'm wondering if someone can give ma a basic run down of the pinout. I know charging pins 1 and 2 sets it and 3 and 4 reset it. (or vice-versa) If I charge pins 1 and 2 that should close pins 6 & 5 and 9 & 8 and charging pins 3 and 4 will close 6 & 7 and 9 & 10. Right? It acts a two pole i think. if thats the case all I care about is 4, 5, and 6.
