GetDeviceInfo
- Joined Jun 7, 2009
- 2,196
I'll be continually monitoring the temperature inside the bin of one of the animals, and adjust the heat output accordingly, the further off from the target temperature the higher the heat output.
sounds like a lot of thermal mass. You could probably PWM these in the frequency of tens of seconds, with an SSR or wetted relay.The flexwatt simply slides into pre-made slots in the animal rack, under each bin.
