How does a single slab of p/n-type semiconductor act under a voltage? Does it just have a series resistance? Does it have a defined voltage drop?
Also why is this used in a Hall Effect sensor instead of just a normal resistive or conductive material? The magnetic field would displace the moving charge in the same way, would it not?
Thanks a bunch!
Thanks a bunch!
