proper way to creamp the 2 way radio jack
Discussion in 'General Electronics Chat' started by chessmonster, Aug 11, 2011.
  1. chessmonster
    Aug 11, 2011
    hi!
    we have a land mobile radio, the one that comes with the separate mic and the radio is separated. (i'm sorry i can't define it precisely)
    so the mic is working all fine, but the jack that you insert to the base radio itself is broken. the lock of the 'looking like rj45' got broken, so it is kind of loose when you use it.
    i considered DIY repair but looking at the wires, there is one that has the same color. looking at the rj45, the sequence goes like this
    (gold or copper conductors facing down)
    green, yellow, BLACK, red, BLACK again, white, a slot with no wire, light blue
    now I am a bit worried with the 2 black wires.
    I was hoping there is a good way to identify the difference between the two.
    any suggestions would be appreciated
    regards,
    simon
  2. gerty
    Aug 30, 2007
    1,154
    304
    What brand of radio is it? What model number?
  3. chessmonster
    Aug 11, 2011
    hi gerty,
    i only have the mic at hand right now. but the brand of the mic is kenwood. or maybe sir you can give me some links or resources where i can get specs when i get the model number?
    sir you from tennekeys right?
    regards,
    simon
  4. gerty
    Aug 30, 2007
    1,154
    304
